Group: DynoMotion Message: 14238 From: kn6za Date: 12/6/2016
Subject: Re: KMotion/KFLOP Test Version 4.34f - Interpreter/Motion Libraries
  Thanks, great stuff here!
Group: DynoMotion Message: 14244 From: kn6za Date: 12/8/2016
   In xp, when I am under the kmotioncnc tool setup, tool/setup files tab. When you hit the > file browser button the application crashes.
  I can change the text on the file directory line just fine, but the browser button does not work.
  I don't need a patch or anything, I can work around this, unless you would like me to test the fix for this, its up to you Tom.
   Andrew
Group: DynoMotion Message: 14249 From: kn6za Date: 12/8/2016
   I thought the file access crash only affected the tool setup page, but it affects the open gcode tab as well. Same result, program crash.
I did not notice this right away because I transfer programs to kmotioncnc via cut and paste into the gcode window, so its still not an immediate problem for me.
   Andrew
Group: DynoMotion Message: 14264 From: Tom Kerekes Date: 12/11/2016
Hi Andrew,
Thanks for the info.  We're still working on it.  It has to do with the new Windows Open File Dialogs that changed from XP to Vista.
Hopefully we'll have a fix soon.
   Andrew
Group: DynoMotion Message: 14267 From: kn6za Date: 12/11/2016
 Sounds great, hope its an easy one to fix.
  Its not causing me any difficulty, this problem is an easy one to work around.
   Andrew
Group: DynoMotion Message: 14268 From: ericncn Date: 12/13/2016
Thank you a lot for implementing that feature!! :-)
EC
---In DynoMotion@yahoogroups.com, <tk@...> wrote :
Fixture/Axis offsets save every 1 second with "Save Always" enabled on the Offset Screen
Many other Fixes and Enhancements
For details see:
KMotion 4.34f Changes
Download here:
http://dynomotion.com/Software/KMotion434f.exe
Please report any issues.
Group: DynoMotion Message: 14271 From: Tom Kerekes Date: 12/13/2016
Trying to Post to Yahoo again...
On 12/13/2016 11:18 AM, Tom Kerekes wrote:
Hi Andrew,
Please try the latest test release to see if the File Open Dialogs now works for you under XP.
http://dynomotion.com/Software/KMotion434g.exe
http://dynomotion.com/Software/KMotion%20Released%20Version%204.34g%20Changes.pdf
Thx
   Andrew
Group: DynoMotion Message: 14273 From: kn6za Date: 12/13/2016
   Got it, will try this out.
   Andrew
Group: DynoMotion Message: 14274 From: kn6za Date: 12/13/2016
   434g has the same problem as 434f. Two computers with xp were tested.
   Andrew
Group: DynoMotion Message: 14275 From: ericncn Date: 12/14/2016
I'm downloading it, thank you!
EC
Hi Andrew,
Thx
Group: DynoMotion Message: 14276 From: ericncn Date: 12/14/2016
Same for me. 4.34g same as 4.34f.
During installation it first said:
"requires Microsoft .NET Framework 4.6.2"
(I hit OK)
a few seconds later it said:
Issues preventing installation:
.NET Framework 4.6.2 isn't supported by this operating system.
Warning:
The program installation service of the windows modules isn't available in the computer.  The installation may not be exectuted correctly.
After that it completed the installation and KmotionCNC was still aborting on file browsing.
As I need to use the machine, I reverted to 4.33 and it apparently works again as before
EC
   Andrew
Group: DynoMotion Message: 14279 From: Tom Kerekes Date: 12/14/2016
Hi Andrew,
I messed up.  Please try this later test release to see if the File Open Dialogs now works for you under XP.
http://dynomotion.com/Software/KMotion434h.exe
http://dynomotion.com/Software/KMotion%20Released%20Version%204.34h%20Changes.pdf
Thx
   Andrew
Group: DynoMotion Message: 14280 From: Tom Kerekes Date: 12/14/2016
Yahoo not posting.  Sending corrected links again...
On 12/14/2016 9:25 PM, Tom Kerekes wrote:
Corrected Links...
On 12/14/2016 9:10 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi Andrew,
Thx
   Andrew
Group: DynoMotion Message: 14281 From: Tom Kerekes Date: 12/14/2016
Corrected Links...
Hi Andrew,
Thx
   Andrew
Group: DynoMotion Message: 14282 From: kn6za Date: 12/15/2016
    434h did the trick. File open works great now.
   Thanks for all the hard work on these updates and feature additions.
    Andrew
Group: DynoMotion Message: 14283 From: Tom Kerekes Date: 12/15/2016
Hi EC,
In case you are not following, Andrew reports Version 4.34h fixes the issue.
The .NET framework is only needed for the other example applications like KMotionCNC Screen Editor so you can ignore the error.   If you need to run those you will need to use a computer with a newer OS.   Any Screens created with KMotionCNC Screen Editor should then run on the XP system.
(I hit OK)
Warning:
EC
   Andrew
Group: DynoMotion Message: 14284 From: ericncn Date: 12/15/2016
Yes! Yes! It works for me, too!  I was testing it right now.
Thank you a lot!
Regarding the possibility to develop the screens on another computer, it's even better!
Thank you!
EC
Hi EC,
(I hit OK)
Warning:
EC
   Andrew
